Badger5AWEsome GTI
Thread: Mk1 TT AWD ???
    Apr 2009
    11
    Post Thanks / Like
    Question Mk1 TT AWD ???
    This is most likely the dumbest qusetion ever asked on this forum but to settle an argument between two non TT owners ....................... are ALL TT's AWD?
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    Post Thanks / Like
    no not the dumbest question, No audi is permanently 4 wheel drive even the a4,a6,a8 quattro, they are all two wheel drive untill differential passes power onto the rear of the car at a speed of approx 10kmph hence why the mot is never a problem on the rolling road.
    the origional TT only came out in quattro at first then introduced the two wheel drive model a couple of years later. however due to the set up of the haldex quattro system the car is only ever in 4 wheel drive mode when required and is activated by the the haldex ecu.
    instances when the tt will engage 4 wheel drive are on full acceleration on sharp turning, or possible when spinning on its axis, which is recognised but the yaw rate, longitudinal and lateral acceleration sensors.
    hope this helps with your argument
    Apr 2009
    11
    Post Thanks / Like
    So it would appear that we are both right in effect!
    Very many thanks for that concise response, much appreciated.
    ianysm's Avatar
    Oct 2008
    UK
    1,001
    Post Thanks / Like
    There is a base 150bhp model that is 2wd only
    Current: RenaultSport Clio 172
    Previous: 2001 ('51) S3 Quattro
    Previous: 2001 E46 M3 Coupe
    Previous: 2001 Civic Type R
    18,288
    Post Thanks / Like
    The bottom line answer is, if we just say audi quattro is considered 4wd by majority of all non technical people, then no the MK1 TT was not solely 4WD, they did a 4WD & a FWD, simple answer to simple question.
    But Foolish is obviously correct its not a permanent full on 4wd system, it works when it needs to.
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
