My drivers window on an 03 plate TT is failing to close properly - staing open about 1cm. Anyone got any suggestions how to fix?
hi ime new to the forum (today) have you used the window reset method
mine is doing the same any resolution to it, its so frustrating, thanks Kaz
Kazza
Sorry, don't look at this one very often any more. Have a look at this:
http://www.wak-tt.com/tt/windows/windows.htm
It sounds like the window either needs re-setting;
- ignition on
- windows all the way down
- windows allthe way up, let go of switches
- push them up again and hold for 3-5 seconds
- ignition off
or you're going to have to fork out for a new regulator soon. The first choice cured Rach's passenger window for a while, then the cable snapped in the regulator, so had to source a new one of those. Not exactly the easiest of DIY jobs I must admit.
NEW 6 cylinder 40mm front springs - £40
PM me for more info
