Backdraft MotorsportVAG Check
    Dec 2008
    Post Thanks / Like
    Why is breaking the timing belt so bad on a TT?
    Ack... just got news from the repair shop that my timing belt broke. I'm waiting to hear the full extent of the damage. I was going about 45 mph when it went. Can someone explain to me why with the TT's interference engine that breaking the timing belt does so much damage? Why are the valves inset so that they can get damaged when the cam shaft stops?
    Jan 2004
    York
    1,639
    Post Thanks / Like
    It's all about efficiency and power.... I'm sure someone with more time will be able to explain a bit more.
    Going ..... '56 Audi A4 2.0 TFSI Sline SE quattro Avant
    To be replaced by a
    11 plate SEAT Exeo CR ST Sport Tech
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Post Thanks / Like
    It's certainly all about efficiency and power.
    The piston has to compress the air/fuel mixture to the smallest possible volume to develop power, and the valves have to open as wide as possible to get air in and exhaust out as quickly and efficiently as possible.
    Unfortunately, as we expect good power AND economy, the valves, when open, have to occupy the same space as the piston does at another point in the cycle. Thus, if the timing belt goes, valves WILL meet pistons.
    You could always buy an old low compression engined car, or find one that uses a chain instead of a belt...
    IIRC, chains are starting to become popular again.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    Aug 2004
    Aberdeenshire
    740
    Post Thanks / Like
    I don't understand why car makers went to belts in the first place. A very unreliable solution to a problem that didn't seem to exist.
    If I was cynical I'd say it was to give dealers work that they might have lost as cars became more reliable.
    However, as alijames said, chains are coming back. All the VAG diesels except the 1.9 and 2.0 use chains (the V10 has gear driven cams which is even better but expensive to produce). I think most of the bigger petrol lumps have chain drive. Not sure about the smaller petrol units though.
