Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    Apr 2004
    atl
    2001 TT quatro 1.8L questions
    I dont want to sound like a dumbass on my first post, but...
    what are the stock whp and torque for a 2001 TT quatro 1.8L?
    is epuipped with all-time AWD?
    twin or single turbo?
    what is the stock psi?
    thats all for now, thanks...
    Apr 2004
    atl
    Re: 2001 TT quatro 1.8L questions
    nevermind, i found the answers to most of the above questions, but i still cannnot find what the stock psi is...
    scoTTy's Avatar
    Essex, UK
    1,957
    I think they are all 36/30 but I owned a 225 (chipped) with 17" and 18" wheels. I don't know about the other models pressure.
    Have you looked inside the feul filler flap?
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    I think he meant boost pressure
    [/ QUOTE ]
    Apr 2004
    auburn alabama
    the stock turbo pressure on an 01 tt 225 is 6 psi or so i have been told by the guys at APR. as far as the bar configuration i have no clue.
    Apr 2004
    atl
    what is the best blow off valve for a tt?
    i have been researching the turboXS bov's and from what i remember, the type s is for up to 10lbs of boost, while the type h handles up to 20...
    what bov would you all recommend?
    scoTTy's Avatar
    Essex, UK
    1,957
    You don't want to fit a BOV. It confuses the ECU and you lose power. Basically it's meant to be a closed circuit so if you vent to atmosphere the car assumes you have a leak.
    If you feel you need to change get an a Forge or AMD Divertor Valve.
