Volks AutosMonster Motorsport
    Feb 2007
    rear shock stripped thread
    Hi guys, could anyone please tell me what the part is called that the rear shock and anti roll bar bolts into, is it the trailing arm, the thread has stripped while changing the shockers and i need to replace it, a part number would be nice if anyone knows, thanks
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Instead of paying for a new part you can get the existing part repaired using a helicoil kit (the kit usually comes with everything you need, you have to supply the drill). This involves drilling out the old damaged threads and tapping a slightly bigger hole. You then screw in a stainless steel spring. The ID of the spring matches the original thread. These are often used to repair threads in soft alloys and the repair is stronger than the orignal thread. Below is a link with some info.
    http://www.britishfasteners.com/Merc...egory_Code=340
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
