AH FabricationsVolks Autos
    Oct 2006
    TT Coupe Headrest Problem
    Hi, My passenger side headrest can't be lowered.
    Any suggestions on how to repair it, or just lower and leave it in the same position?
    ...Doc
    Pimpster's Avatar
    Rolling Thunder...
    Feb 2005
    Leicester
    65
    A possible cuase of this is the metal rods going down are bent, hence stopping it going down any further. Remove the headrest completely, and check the intigruity (sp?) of the metal rods... also look down the holes, where the rods go into and ensure that nothing is stuck down them, maybe stick a screwdriver down just to make sure nothing is there.
    Pimpster
    Oct 2006
    I have tried to pull the head rest out but it stops at the up limit.
    I was worried about pulling too much and something might break.
    Any other things I can try?
    Pimpster's Avatar
    Rolling Thunder...
    Feb 2005
    Leicester
    65
    It shouldn't stop mate, they do come all the way out. If you've run out of room, just tilt the seat backwards a bit. It's going to be your only way mate.
    Pimpster
    Oct 2006
    I'll give it a try.
    Thanks.
    WannaSeeMyTT?'s Avatar
    GA TT Owner
    Mar 2007
    Columbus, GA, USA
    Are the headrests adjustable in the Coupes? I have the convertible roadster and the headrests are not adjustable.
