Volks AutosSky Insurance
    Jun 2006
    7
    Headlight removal
    Doen anyone have a guide on removing/fitting the headlights on an 2003 TT roadster? I've searched high and low with no avail.
    Can anyone help?
    Remaps! Get Yer Remaps!!
    Nov 2006
    Watford
    Hope this helps....
    BUMPER REMOVAL
    1 ) Jack up, remove front wheels
    2 ) Remove front part of fender liners
    3) Remove the 2 10mm nuts on studs at
    the corners toward the sides holding the
    nose to the body shell. Loosen 2 torx
    bolts holding black side clip
    4) Remove the 6 torx bolts along the top of
    the nose
    5 ) Remove 2 phillips screws at the bottom
    6) Pull nose off, unclip aliens.
    HEADLIGHT REMOVAL
    R emove the 3 TORX BOLTS
    1 ) Remove front one
    2 ) Remove top one
    3) Loosen bottom one (from inside the
    wheel well) and flip support bracket
    out of the way
    4) Wiggle out and unplug
    Wak
    Feb 2003
    37
    full pictorial instructions here
    http://www.wak-tt.com/mods/angeleyes...o/fittings.htm
    There are 3 torx bolts but none inside the wheel well.
    The headlight has two top bolts and a front bolt behind the grill
    Then a locating peg at one corner.
