AH FabricationsChris Nott
    Dec 2004
    39
    Audi TT roadster softtop problem :(
    hello all
    i have recently started to get a warning light constanly on in my audi TT roadster, let me try and explain:
    when you release the hatch to bring the hood down a warning light appears on the bashboard when the roof is down the lights goes out,
    when you bring the roof back up the windows drop slighty, you hook the hatch back in the warning light should turn of, this is my problem the warning light stays on and the windows dont go back up either when i close the roof.
    has anyone experiened this or does any one know why this light stays on, any advice will be great. i have notice there is a kind of button which the hatch pushes in when closing could this be the problem??
    ButchsTT's Avatar
    Oct 2006
    Puerto Rico
    69
    Light for the top si on
    I had the same problem and there is a sensor in the top panel that sense if the top is closed properly Mine had to be replaced after a year it has started again I just thump the handle for now and the light goes out so far will probably have ot have it replaced again
    Dec 2006
    If you will notice where the roof pins bayonet into the winshield frame, look closely and you will see lever switch be depressed. You can slightly bend/ adjust it back into position so when the pin comes down the switch will be made fully. Your lights will go out and your windows will close.
    Good luck,
    Terry
