JMB RetrofitsChris Nott
Results 1 to 7 of 7
    Feb 2014
    Dashboard Millage Fault :(
    Hey Guys,
    I have seen a similar topic to this a few years ago but it didn't really help me out.
    I have an Audi TT (2001) and have I just used VAG Tacho 2.5 to reset the mileage. But now it reads 999999. Even after driving it the mileage stays at the same.
    I believe I need to talk to a specialist dashboard company to help me with this issue. Im from Derbyshire if anyone is local?
    27,102
    Welcome to the site.
    What was wrong with the mileage beforehand, cluster fault & fitted replacement used cluster?
    Feb 2014
    There was nothing wrong with the millage before. My engine warning light came on and i was trying to check the faults. But i played around with Vag Tacho a little too much and buggered it up.
    May 2012
    RETFORD, NOTTS
    1,753
    I can fix this. Where abouts in Derbyshire are you?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Feb 2014
    I'm from Belper. How much would you be looking to fix this?.
    Oct 2012
    Hull
    12
    This issue occurs when the checksum is incorrect inside the instrument cluster. This occurs often using the wrong tool on some versions of the Audi TT and Audi A3 (8L). It can now only be fixed by a specialist.
    May 2012
    RETFORD, NOTTS
    1,753
    Clone vag tacho is a nasty tool, would only ever advise reading info with it, never writing. Ideal if you already have say genuine VCDS and just need your skc, but sometimes even then its no use!
  1. dashboard lights
    By A4Steve in forum Classic Audi Forum
    Last Post: 13th December 2007, 10:03
  2. All dashboard needles are dead
    By gjames11 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th October 2003, 06:59
  3. All dashboard lights out on A4?????
    By MarkR in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd July 2003, 13:11
  4. Intermittent Fault Warnings
    By A4Owner in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2003, 11:23
  5. Internet fault
    By Wolfsburger in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 2nd June 2003, 01:32
