MONKIEE
I have a 2009 TT S Line TDI it has adaptive xenon s with the bulb DRL, I have purchased a set of 2009 TTS xenons with LED DRL I have popped the new lights in situ the plugs are identical and the lights plugged straight in, however the adaptive leveling and the LED DRLs do not work???????
It says sight light / daytime running light left side and adaptive level defective on the dash when ignition is turned on?
As I have effectively changed from a filament bulb DRL to LED will the car need recoding on VAGCOM in order for all to work?
All help is much appreciated!
