Rnse
tomos8304
Hi my rnse has suddenly decided not too work it lights up perfectly and plays all the tracks but there is no sound coming from it at all even if I try the radio or satnav it doesn't even make the sound when I connect too Bluetooth I've taken the back panel off too look at the Bose amp but it all looks ok it's not damp or corroded unless it's inside the amp, but there is no moisture in the boot at all. Any help would be muchly appreciated.
pull the fuse and leave over night they try
if no look scan for faults
Thanks I'll try that it just seems odd how it's stopped working instantly no hissing or anything just complete silence it doesn't even let me make phone calls thru the hands free
It's not uncommon for Bose AMPs to fail, see if you can find someone local to you to try another Bose AMP.
But would it just go silent with no warning it was working perfectly the night before no crackling or anything like I say everything is working normally just no sound no hissing or anything my Mrs rang me too see if that worked she could hear me but it was deadly silent in the car
Hi tomos8304,
Did you get this fixed?
I seem to have the same/very similar problem.
Climbed into my A3 with factory fitted rnse turned the radio on and no sound came out. It appears to be functioning totally as it should just with no sound and intermittent popping of all speakers simultaneously every 15 seconds.
I've had to remove the fuse as it drained the battery the other day.
I have checked the bose amp in the boot and wiring in the door shuts and all seems to be as it should.
I plugged it into my vcds and have the following codes. The only relevant ones seem to be the connection to the right speaker. Could that be the cause of this "no sound" issue?
I'm thinking maybe bin it and buy another, or hopefully somebody else has some info to help?
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 HW: 8P0 035 192
Component: RNS-E HIGH EU H55 0550
Revision: 08S Serial number: AUZBZ7E0302683
Coding: 0209115
Shop #: WSC 06314 000 00000
VCID: ECD744DCCFD00C7ED8B-80B9
7 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 2
Reset counter: 155
Mileage: 69389 km
Time Indication: 0
Date: 2010.01.27
Time: 05:29:57
Freeze Frame:
Voltage: 11.90 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 155
Mileage: 69389 km
Time Indication: 0
Date: 2010.01.27
Time: 05:00:12
Freeze Frame:
Voltage: 11.90 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 115
Mileage: 47431 km
Time Indication: 0
Date: 2008.09.29
Time: 12:16:48
00879 - Connection to Speaker Front Right
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 5
Fault Frequency: 3
Reset counter: 155
Mileage: 123753 km
Time Indication: 0
Date: 2014.01.20
Time: 12:44:52
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 115
Mileage: 47431 km
Time Indication: 0
Date: 2008.09.29
Time: 12:16:48
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 10
Mileage: 47431 km
Time Indication: 0
Date: 2008.09.29
Time: 12:16:37
02005 - Coding Pin
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 10
Mileage: 47431 km
Time Indication: 0
Date: 2008.09.29
Time: 12:16:57
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209115
7 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 155
Mileage: 69389 km
Time Indication: 0
Date: 2010.01.27
Time: 05:29:57
Freeze Frame:
Voltage: 11.90 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 155
Mileage: 69389 km
Time Indication: 0
Date: 2010.01.27
Time: 05:00:12
Freeze Frame:
Voltage: 11.90 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 115
Mileage: 47431 km
Time Indication: 0
Date: 2008.09.29
Time: 12:16:48
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 155
Mileage: 123753 km
Time Indication: 0
Date: 2014.01.20
Time: 12:44:52
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 115
Mileage: 47431 km
Time Indication: 0
Date: 2008.09.29
Time: 12:16:48
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 10
Mileage: 47431 km
Time Indication: 0
Date: 2008.09.29
Time: 12:16:37
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 10
Mileage: 47431 km
Time Indication: 0
Date: 2008.09.29
Time: 12:16:57
Yes it's sorted now it was the amp my mate fixed it for me for £60 the circuit board had fried if your a member of the tt forum he has posted a detailed fix procedure & the moderators have made it into a stickie for everyone too use, but unless your good with electronics I wouldn't bother, most companies were quoting about £250 too repair it & I had no luck with Audi UK, unfortunately it's a common problem hop u get it sorted.
