Chris NottVolks Autos
    Apr 2013
    Rear light intermittant fault
    My 2008 TT has developed a fault (on the outside of the two) off side rear light , it will come on for about 10 secs and then go out. I have just changed the bulb and the same thing is happening again. Any Thoughts? The inside bulb of the two is working perfectly.
    Thanks for any info.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,424
    did you check the bulb holder for corosion ?
    give it a clean up with wire wool
    Apr 2013
    Smile
    Thanks Bez for that, I will certainly try that in the Morning
  1. Audi A4 - Rear Light Bulbs Fault
    By amz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2012, 19:26
  2. Parking light (Rear Number Plate) Fault - 2004 S4
    By Sulli in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st February 2012, 22:05
  3. A6 Rear Lights
    By skidooman in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd November 2003, 12:29
  4. Smoked Rear Light Lenses for 2003 A6 Saloon
    By cliffcartwright in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th October 2003, 14:28
  5. Intermittent Fault Warnings
    By A4Owner in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2003, 11:23
