Chris NottAH Fabrications
    Mar 2013
    Durham
    how to remove the front grill on a mk2 TT?
    Hi does anyone have a guide to removing the front grill off a mk2 TT? i want to replace the Badge but it sems to be a pain in the @rse!
    any help would be appreciated!!
    Mar 2013
    Durham
    Hi Ive just found a decent guide so if anyone else need sto know here it is!!... :o)
    quattroworld.com Forums: TTRS bumper removal and grill install
    27,129
    Usually if you pull the badge towards you & then get a finger behind or angled tool (if the slats aren't to small to get a finger between) then you can push the expanding clips inward & the pressure from pulling towards the front usually pops them out, unless the fixing has changed some.
    Mar 2013
    Durham
    I'll give it a go, i tried yesterday anf the badge was stubborn to say the least!
    Aug 2013
    Biggar
    21
    It is easier taking the front bumper off
    Jimgrim77's Avatar
    Nov 2011
    Clevedon, Near Bristol
    957
    without trying to hijack the thread, to remove the chrome front grill surround, is it like older/other audi models and simply a case of using a flat head screw driver to tease it out all the way around or what?
    I fancy the all black look and am looking to have it sprayed by would appreciate some guidance.
    Thanks in advance
    Ming Blue S3, Stage 3 Hybrid Turbo, Custom Map, Bosch 480 injectors, Custom TIP, Forge FMIC, 3" Downpipe, 200 Cell Sport CAT, Full Stainless, XS Power Mani, 6 Paddle Clutch, Red silicone hoses, LCR Brembo's, Forge 007p, KW Suspension Kit, Green filter, THS Mounts, 11mm & 16mm spacers, H&R Anti-roll bars, RS6 18" alloys, Michelin PS3's, Red Dog Bone Mount, Neuspeed quickshift, Boost Gauge, Aero wipers, LCR splitter, Forge Tie-bars, LED bulbs, Armrest, Custom TT pedals.
  1. How to remove the front headlight
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2013, 12:26
  2. How to Remove the Front Bumper?
    By ScottishS3 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 14th October 2012, 21:08
  3. How To Remove The Front Grill?
    By S3 Vermin in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 13:12
  4. How to remove the front light clusters?
    By auditurboquat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th August 2007, 18:44
  5. How to remove the Front Seats? Any Body?
    By Offtrack4Speed in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2007, 18:54
