EM TuningMonster Motorsport
Results 1 to 10 of 10
Like Tree6Likes
  • 1 Post By NHN
  • 1 Post By Veneeringman
  • 1 Post By 45bvtc
  • 1 Post By 45bvtc
  • 1 Post By SilureMark
  • 1 Post By MrBones
Thread: squeaky brakes
    dbw
    Jul 2013
    squeaky brakes
    Can anybody help! Since purchasing our tt rs 15months ago the brakes continue to squeak!
    We have had replacement discs etc Still squeaking!
    Milton Keynes had the car for one week all very top secret. car returned to us appeared to be ok but now squeaking again!!
    Audi are perplexed that we are saying the squeak is back!
    We are still waiting for them to decide what course of action should be taken1
    if anybody has had a similar problem we would love to hear from you.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Have a look in the rs3 section, the boys in there are familiar with the brake squeal. Afaik the brakes are the same. x
    27,114
    Welcome to the site.
    Yes as Sandra advises, check the RS3 boys as this is as common as Eastenders
    Sandra likes this.
    Veneeringman's Avatar
    Bazinga
    Aug 2010
    Back in the UK
    650
    Hi dbw, I own a RS3 and same thing it had squeaky brakes, booked it into Audi centre in Stockport where they replaced all front brake components, 1000 miles later it did start again a little and the brakes didn't inspire confidence, however after speaking to a brake component company they suggested a few good sessions braking from 60 to 0 (safely mind you) to get the discs and pads warmed up, this de-glazes the pads and helps bed the whole set up in properly, and to be honest the whole set up is miles better now and they rarely squeal if at all.
    Part of this is Audi not telling customers the right information, doing the upgrade then just handing the car back to customer regardless of wether the new set up is any better.
    NHN likes this.
    2012 Misano Red RS3 / Bucket seats Heated front & Rear / Aluminium Styling Pack / Bose / RNS-E / Bluetooth / Mobile phone prep low / AMI / Reversing Sensors / LED number plate lights / Led interior light pack / VCDS / Cruise Control / Exclusive Inlays / Auto Lights & Wipers / 8.5J fronts / extended leather / Michelin Pilot super sport tyres / and a few other things
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,299
    Veneeringman is right, the issue with the upgrade does seem to be with the bedding-in process, however, there is another solution that worked with the original brakes and will work with the upgrade too. PM me if you want details (as listed in the RS3 section).
    Otherwise try the Brembo sport pad, again advertised in the RS3 section; that works too - and produces a lot less dust!
    NHN likes this.
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,299
    And here's the Brembo Brake Bedding procedure (taken from the Brembo Sport Brake Pads data sheet):
    For information:
    It is very important to follow proper brake bedding procedure following installation. This is necessary not only for optimum performance of the system, but also to avoid onset of judder (vibration felt through brake and steering).
    When fitting pads to used discs, the discs must be in good condition and be within the original manufacturers manufacturing tolerances. In case of any doubt, new discs should be fitted.
    Be aware that with new brake system components, the braking performance will be reduced until the pads and discs are fully bedded. Use extreme caution while driving the vehicle under these conditions. If done on public roads obey all traffic laws and do not endanger yourself or others.
    The purpose of this procedure is to gradually increase the temperature in the components without thermal shock and to mate the brake pad and disc friction surfaces, generating a uniform transfer layer.
    Perform at least 20 brake applications using medium deceleration (approximately 60% of maximum) starting from 60mph and slowing to 20mph. Do not come to a stop. Accelerate back to the starting speed allowing 20-30 seconds before beginning the next brake application. After completion, drive the vehicle for at least 5 minutes with little or no braking in order to adequately cool the components.
    When it can be done legally, or on a closed circuit, a secondary bedding operation is beneficial.
    Repeat the above procedure for 5 to 10 brake applications increasing the starting speed to 80mph and increasing the deceleration rate to 80% of maximum. After completion, drive the vehicle for at least 10 minutes with little or no braking in order to adequately cool the components. The system is now ready for normal use.
    This entire procedure must be complete before driving the vehicle as normal. It is especially important that this process is completed before any extended same-speed driving is done (i.e. Motorway travel). Failure to follow these instructions greatly increases the likelihood of judder development.
    MrBones likes this.
    Jul 2013
    Essex
    270
    Had the same issue with my car and was initially fobbed off by the Dealer - 'brakes do that' sort of conversation. Anyway, after giving the service manager an earful they replaced the pads under warranty and it has been squeak free ever since.
    45bvtc likes this.
    S3 Misano Red | s tronic | super sport seats | black styling pack|10 spoke matt titanium alloys | privacy glass|technology pack high with mobile | audi sound system | through load | light & rain sensor pack | rear parking sensors | electric folding mirrors | tyre pressure monitoring | non smoking pack | registered 06/06/2014
    Going Gone Bye
    May 2013
    Stroud, Gloucestershire
    32
    Quote Originally Posted by 45bvtc View Post
    For information:
    Great info....thanks
    45bvtc likes this.
    dbw
    Jul 2013
    thanks so much for your help will try out breaking procedure, and let you know how I get on. cheers Dave and bev.
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,299
    Quote Originally Posted by dbw View Post
    Dave, maybe you should talk to me.
    If you've the original brakes (1) then I can sort it easily; I can send you an illustrated procedure, chapter and verse: all you'll need is some £4.99 self-adhesive anti-squeal shims and a couple of hours labour - job done.
    However, if you've the upgraded brakes then make sure you undertake the bedding-in procedure first; if that fails then go back to (1).
    A 3rd alternative is to use the Brembo Sports brake pads - these are 'claimed' to stop brake squeal - though are NOT Audi approved.
    Back to (1): I've been using Mintex self-adhesive anti-squeal shims on my own 'original' RS3 brakes for the past 18-months, and have applied it to a number of other RS3's, successfully.
    LOTS of information on the RS3 forum (RS3 and TTRS brakes are basically the same)
    I'm in Staffordshire - WS12: your choice...
  1. Squeaky Brakes?
    By JPD125 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2008, 22:27
  2. Squeaky brakes?
    By KRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th November 2007, 13:35
  3. Squeaky brakes
    By PorkyWill in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2007, 12:37
  4. Squeaky Brakes
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2006, 17:03
  5. RS6 has squeaky brakes like a routemaster bus
    By installer69 in forum RS6 Forum
    Last Post: 7th October 2005, 22:07
