vaslam1986
Really in need of some help here guys. Got a MK1 TT (04) for a cruise control retrofit, oncee i completed the retrofit and put everything back together only to find that the car does not start. The PRNDS on the DIS is constantly flashing. The car does not turn over at all. I ran VCDS scan on it and have found that there is no communication with the ECM. I checked all the wiring etc and still no joy. As a last resort, i've taken the cruise control stalk and wiring out but still no joy. Any help ideas will be greatly apprciated.
VCDS Log:
VCDS Version: Release 11.11.6
Data version: 20121223
Tuesday,16,July,2013,21:30:24:15161
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: TRUZZZ8N941024501
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 046 F HW: 02E 927 770 L
Component: GSG DSG 0603
Revision: 03149888 Serial number: 00000402140099
Coding: 0000020
Shop #: WSC 01236 785 00200
VCID: 1A3DEC2BD6A480C8CEF
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Address 03: ABS Brakes Labels: 8N0-907-379-MK60-A.lbl
Part No: 8N0 907 379 K
Component: ESP ALLRAD MK60 0102
Coding: 0022548
VCID: 4481725304A0E638443
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00041
Shop #: WSC 01236
VCID: 2859C6E3C8C8225848B
No fault code found.
Address 15: Airbags Labels: 8N0-959-655.lbl
Part No: 8N0 959 655 D
Component: Airbag Front+Seite 0000
Coding: 01102
Shop #: WSC 01236
VCID: 418F7B474BB2F3106F5
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N2 920 980 D
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 01462
Shop #: WSC 00847
VCID: 387916A31868B2D8D8B
TRUZZZ8N941024501 AUZ5Z0D1265042
4 Faults Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
49-00 - No Communications
01304 - Radio
49-10 - No Communications - Intermittent
01305 - Databus for Infotainment
37-10 - Faulty - Intermittent
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 D
Component: HALDEX LSC ECC 0011
VCID: 214FDBC7ABF2D3100F5
1 Fault Found:
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N8 962 267 E
Component: Zentralverrieg.,DWA D09
Coding: 06858
Shop #: WSC 01236
VCID: 4383714F51AEE1007D9
4 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01559 - Drivers Door
58-00 - Can't Lock
60-00 - Won't Safe
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
Shop #: WSC 00000
VCID: FCF14AB3ECD0DEF8FC3
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
VCID: E5C70FD77F5A7F3033D
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 152 E
Component: chorus II GRO 0001
Coding: 00302
Shop #: WSC 01236
VCID: 1B33E92F899EF9C0D59
1 Fault Found:
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
VCDS Log:
Coding: 0000020
1 Fault Found:
Coding: 0022548
1 Fault Found:
Coding: 00041
Shop #: WSC 01236
Coding: 01102
Shop #: WSC 01236
Coding: 01462
Shop #: WSC 00847
4 Faults Found:
01304 - Radio
1 Fault Found:
Coding: 06858
Shop #: WSC 01236
4 Faults Found:
35-00 - -
58-00 - Can't Lock
60-00 - Won't Safe
Coding: 00001
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 01236
Coding: 00302
Shop #: WSC 01236
1 Fault Found:
