JMB RetrofitsChris Nott
Results 1 to 7 of 7
    Jul 2013
    Belfast
    Nightmare mystery overheating tt
    Hi folks im have a nightmare with an audi TT 180 1999 with full service history 94k i just bought...... problem is the car is overheating....it runs between 94c while driving and 107c when in slow traffic and on a hill according to the 49c aircon test....... the dash guage is at 120+ in the red.....the 51c test show the engine at 90c im not getting any boil over no hoses blown off of steaming expansion bottle but the engine bay is like an oven when opened
    i have changed the water pump,
    thermostat,thermostat housing,
    flushed the cooling system,proper mix of g12,
    a new coolant temp sensor.....
    also full service new oil,filter,timing belt,drive belt,tensioner,damper,air filter,
    oil levels are just over 3/4 on the dipstick
    im at my wits end you can really feel the heat in the engine bay it's actually starting to affect belts and stuff it's so hot......
    the fans were not kicking in either aircon or main fan so i wired them to a switch and relay to be on full time still makes no difference to the temp.....
    i have ordered a new fan control relay for the rad fans but still cannot figure out why its running so damm hot with the fans on all the time......you can feel the heat blasting out the front of the radiator too
    the new water pump seems to be circulating ok in the expansion bottle....both rad hoses are hot...a little firm.... so i thought head gasket.........but hot air is fine in the cabin...no white smoke.....no coolant loss or coolant in the oil or oil in the coolant....no power loss.......no mayonaise under the cap...........im freaked out dont know what else to do......pls guys any help im really up a creek here any experienced members or vag mehanics i really need your help......
    Apr 2013
    Aberdeenshire
    592
    Sounds like an issue with your fans check the fuses but have a scan done ASAP to prevent head damage
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by Chillout View Post
    Just read your thread with my eyes open do you have good return to the header tank.
    Jul 2013
    Belfast
    hi thx for the reply i flushed the cooling system yesterday and the water seems to be getting through the hoses from radiator into the engine and out of the engine via the thermostat housing also it looks like the water is circulating in to bottle ok and returning via the small to hose it's weird...i drove it yesterday at full tilt absolute redline driving for over 30 mins and the temp was sitting nice at 93c and on a motorway at 70 she sits at 86c for over an hour it seems when i slow down it sky rockets,thats the strange part as i have hardwired both fans to be on constantly until i get my new fan control relay...
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by pawea View Post
    I take it you hoses in and out are hot and you don't have air locks also that both fans are pulling air in from the front and for example one is not blowing causing short cycling of air if they can run with reversed polarity as normal dc motors can
    Jul 2013
    Belfast
    Smile
    The very thing....cheers chillout good thinking man i rewired the fan polarity and all is well temp normal now
    Apr 2013
    Aberdeenshire
    592
    Spot on glad you got it sorted
  1. mystery overheating, please help????
    By alistair666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2008, 08:08
  2. The mysterious case of the disappearing thread
    By MushroomMan in forum Site Support & Announcements
    Last Post: 6th November 2003, 09:33
  3. Can someone please unravel the mystery?
    By wigginer in forum Other Brands & Models
    Last Post: 31st October 2003, 18:19
  4. Insurance nightmares
    By noodle in forum General Chat
    Last Post: 21st October 2003, 05:19
  5. Overheating A6 1.8T
    By SteveX in forum General Technical / How To
    Last Post: 23rd September 2003, 21:50
