EM TuningAH Fabrications
    HELP - Fuel Meter on DIS not functioning Properly
    Hi the Fuel Meter on DIS is not functioning Properly on my 2001Y 225 TT. Ran out of fuel the other day as a result - it told me i had 45 miles to go! 'Miles to go reading' is Fluctating when driving very randomly.
    Anyone else had this problem? is the cold weather to blame? whats the fix and how much is it likely to set me back!!!!!
    Thanks in advance
    fraz
    scoTTy's Avatar
    Essex, UK
    1,958
    Re: HELP - Fuel Meter on DIS not functioning Properly
    It could be one of two things :
    TT's have two tanks linked together and fuel gets pumped between them. If one of the fuel sendors fail you get the sort of problem you describe.
    Otherwise it sounds like a dashpod failure but from your description I expect the sendor problem which is good news from a cost perspective.
