Hi,
First i need to say i am not too technical with cars - I will try and explain issue best i can - but any advice needs to be in lamens terms if possible please!!!
My TT started suffering a problem a while ago - when in a low gear the red battery light would come on and the car would stall. I would have to restart the car and it would be ok for a while - and would then cut out again.
The revs would go and it felt like i had just let the clutch out with no revs - it would jutter to a halt.
The garage i took it too reset the fault on the computer - couldnt tell what problem was and gave it back to me!
It was fine for a month or two until it happened again.
This time the emission light - the yellow tap shaped one - also came on in conjunction with the red battery shaped light.
The AA had to be called as this time i just couldnt get it going. The guy said it was a problem with the power and underperformance - the code for the fault was P3923.
He rest the computer and again it seemed fine.
I took it back to the garage but as the fault had been reset - they again said they couldnt tell what problem was!
Audi want £144 just for the diagnostic!
Was hoping someone could guide me on what to do!?
Any help is massively appreciated!
Joe
