JMB RetrofitsEM Tuning
Results 1 to 9 of 9
    Jan 2013
    Nottingham, United Kingdom, United Kingdom
    29
    Mk1 tt spluttering under load (1.8t 225bhp)
    Hi!
    got some issues with my girlfriends tt, it has a bad splutter under load/boost, at its worst in third gear about 3000rpm which at times makes the eml light flash. I've plugged in vcds and it just came up with random multiple misfire. It had new plugs about 5k ago. Wired thing is, it's smooth on idle and drives well when not booting it!
    Was just curious if there was a common fault that may cause this?
    i was thinking coils, but would have thought that would be a constant misfire on idle ect
    or maybe a maf? But would have thought that would flag a fault in the memory?
    only other thing there was an old fault that cleared and didn't come back, relating to the inlet cam sensor.
    cheers for any help given!
    Jan 2011
    northants
    165
    i would run it and see if missfire fault reappears
    if it does then do coil packs
    Apr 2013
    83
    almost gurantee its coilpacks. Still half price at psi tuning!!! worth it just for a spare set imo
    Genuine VAG Red Coil Pack Set - 1.8T > Engine > Leon Mk1 1999-2005 > SEAT Leon > VAG Specialists > PSI Tuning - VW Specialists
    Apr 2013
    83
    \Just to add i had EXACT problem with my 1.8T after a remap, Idle was smooth, gentle throttle and light load was smooth....then bang misfires under boost with light flashing wild, eventually got so bad the light stayed on permanently...changed packs and all was good again
    Jan 2013
    29
    Brill cheers for the help! Will get the coils changed after reading this, will post when I've done it!
    Jan 2013
    29
    Booked in at audi for ignition coil recall! Wahooo
    Apr 2013
    83
    Quote Originally Posted by Jackhop22 View Post
    Result
    27,097
    Yeap recall would be my 1st suggestion, result
    Jan 2013
    29
    picked up the tt yesterday, gutted! turns out only one of the coils are originals so only got one replaced! :/ ... and the misfire under load fault still remains!, looks like i will have to get the wallet out now!
  1. A4 1.9 TDI pd 130 misfire - cough/mis/splutter under load - judder on idle
    By ian-r in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2012, 20:09
  2. 2.5 v6 TDi Quattro vibration under load
    By noddyr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd September 2009, 12:24
  3. can't get full revs under load
    By otisdomino in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th January 2009, 23:32
  4. Power loss under load (TDi 130)
    By smo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2008, 14:03
  5. 1999 S4 - gearbox clunking under load... :(
    By brixo in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2006, 12:33
