Volks AutosAH Fabrications
Results 1 to 8 of 8
    Sep 2008
    London
    49
    Unhappy HELP!!!! Car Not Starting After Coil Pack failure
    Can anyone help me out!!!!
    My forth coil pack burnout while driving which made the car come to a slow stop...I ordered the repair kit from Audi and got the mechanic to wire the new kit in. I replaced all four packs and connectors also.
    All errors was cleared but the car is not starting, the ECU is still communicating with the car, all the lights on the dash are fine but the car will not firer up .
    Has anyone got and ideas why the car is not firing up
    How do you change a DSG gear selector?
    Also can I fit a newer model selector (facelift) to a older model (2007/8)
    26,762
    Have you checked the spark plug aswell?
    Sep 2008
    London
    49
    New plug and coil packs have been added...do you think it needs to me reset by a Vagcom because we also notice that the coils are not sparking
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    if all connectors wired correctly. That circuit is protected by it's own fuse, look there
    Sep 2008
    London
    49
    Do you know where the circuit/fuse will be because i know on some audi have a fuse under the ECU
    26,762
    In order to verify the fuse point, you'd need to have engine & gearbox code to check within elsa.
    Sep 2008
    London
    49
    After a next to a sleepless night a light turn on to one of my first thoughts....I said to my self that they must be a protective fuse if the pack melts and I was right. There is a 20amp fuse in the engine fusebox that went...replaced and all running well woo hoo
    Thanks guys for you help
    Apr 2004
    12,357
    I told you that, glad to help.
  1. Help needed ASAP please. Possible coil pack failure?
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2013, 21:06
  2. S3 225 - ESP light on after coil pack recall ?!? - Help Please!!
    By jimbob442 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd March 2012, 17:21
  3. Car not starting, Help please guys.
    By chris-edin in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2011, 10:34
  4. Coil pack failure after remap... just unlucky?
    By mikeyw in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th February 2011, 19:55
  5. Car wont start after cleaning starter motor - help!
    By ptr in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2010, 10:09
Tags for this Thread
