AH FabricationsEM Tuning
    Dec 2006
    46
    Low mileage 2001 Audi TT; buying advice please
    Hi,
    I am looking at an Audi TT from 2001 that only has 29k miles on it. Is there anything I should be looking out for? My knowledge of TTs is virtually zero so any advice is greatly appreciated.
    And other than using VCDS, is there a way to read the fault codes from the car?
    Thanks in advance
    Jun 2010
    East Manchester In the Hills !
    672
    A 12 year old car with mk 4 golf suspension !
    Make sure all the top mounts have been done as well as the suspension bushes as if haven't they will be perished.
    Check the instrument cluster all works. Common fault on these.
    Also see if the Cam Belt and water pump has been done, if not budget 300 to 450 to get it done
    Other than this a check with VCDS to see if there any faults and the usual checks you would do on any car.
  1. looking to buy audi a3 2.0tdi sport 3 door any buying advice please
    By conorw in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2012, 12:23
  2. Audi Coupe buying advice please
    By sym0n in forum Classic Audi Forum
    Last Post: 19th April 2010, 20:05
  3. A4 Buying advice please
    By jvbates in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th January 2007, 17:51
  4. Audi A4 1.9 TDI 110 - General Info and Buying Advice Please :)
    By DelBoyUK in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd December 2005, 12:26
