1999 Audi TT QC 225. Help with Vag-Com results
yummymummy
NULL
Attached are my Vag-Co results. Anyone have any idea what would cause this?
kind regards
Sunday,03,March,2013,12:10:19:44690
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: XXXXXXXXXXXXXXXXX
Address 01: Engine Labels: 06A-906-032-APX.clb
Part No: 8L0 906 018 M
Component: 1.8L R4/5VT 0002
Coding: 05710
Shop #: WSC 01236
VCID: 397D72CF23F700D0262
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18446
Shop #: WSC 01236
VCID: 3E7761D33AD927E8130
2 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
57-10 - Electric Circuit Failure - Intermittent
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00041
Shop #: WSC 01236
VCID: 285BA78BC85D895849C
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seite 1005
Coding: 10102
Shop #: WSC 01236
VCID: F7F934F7D56356A0906
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N2 920 930 C
Component: KOMBI+WEGFAHRS. M73 D56
Coding: 05444
Shop #: WSC 00031
VCID: 326F45E3FE81F388E78
XXXXXXXXXXXXXXXXX AUZ5Z0L0105022
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F49BC579D134EE0386
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N7 962 267 B
Component: Central Lock/Alarm D04
Coding: 04826
Shop #: WSC 01236
VCID: 3F891CD73DD32EE0186
4 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01559 - Drivers Door
60-00 - Won't Safe
01134 - Alarm Horn (H12)
77-00 - Internal Supply Voltage
01617 - Please Check DTC Memory of Interior Monitoring
35-10 - - - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N7 951 177
Component: Innenraumueberw. D13
Coding: 00001
Shop #: WSC 00000
VCID: FBF128C7E94B72C0F4E
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
81-00 - Open
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
VCID: E5C56EBF7FCFD43032A
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186 D
Component: Radio D05
Coding: 00017
Shop #: WSC 01236
VCID: 214DBAAFAB6778100E2
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 22: DTCs cleared
Address 35: DTCs cleared
Address 45: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
2 Faults Found:
This sounds like Throttle pedal, drive by wire throttle problem.
You asked your question and got your answer, no need for the crappy attitude.
(Thread edited to show just the information requested and answer given)
I have not deleted this thread as the question asked may help others with the same problem. The OP has a bad attitude towards people who are trying to help him, so its up to you lot if you want to help them out with any other questions they may want to ask on here.
