Sky InsuranceJMB Retrofits
Results 1 to 10 of 10
    Jan 2013
    31
    Lightbulb Stiff steering wheel
    HI EVERYONE,
    NEED SOME ADVICE ON MY AUDI TT STEERING WHEEL ITS VERY STIFF IT DON'T FEEL LIKE A POWER STEERING WHEEL. I WONDER IF SOMEBODY HAD THE SAME PROBLEM AND COULD ADVICE ME ON IT. THANK YOU YOUR TIME
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    891
    Re: Stiff steering wheel
    Could be anything from a low/flat tyre to a power steering pump failure.
    How old is the car?
    Is it making any unusual noises?
    Does the steering also feel notchy?
    Shaun.
    Jan 2013
    31
    THANK YOU FOR YOUR REPLY
    THE CAR IS 1999 AUDI TT
    NO NOISE
    THE TYRES ARE FINE
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    891
    I would start by checking if there is any fluid in the PAS reservoir and go from there. If it has lost all its fluid, there could be a leak in the system somewhere which would cause the system to lose its pressure and create the heavy steer feeling.....almost like trying to drive a train around corners.
    Jun 2011
    Great Melton Norfolk
    1,356
    Power steering or Top mount bearings broken up.
    27,126
    This is probably related to your other thread with cluster showing loads of lights, get it on vcds.
    Also tone the text down with caps lock of please.
    Jan 2013
    31
    so many ppl have problems with caps lock
    27,126
    Ye its really hard pressing that caps lock button huh
    Jan 2013
    31
    27,126
  1. Steering Wheel Stiffness on 2.0TDI S Line
    By Nza in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th May 2009, 23:34
  2. steering wheel noises
    By Inigo in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2003, 13:50
  3. Tiptronic steering wheel
    By TheTonsta in forum General Technical / How To
    Last Post: 31st August 2003, 18:57
  4. pc steering wheels
    By badbaz in forum Video Gaming
    Last Post: 10th August 2003, 14:33
  5. Steering Wheel Remtoe for stereo?
    By AutoMatt in forum In-Car Entertainment
    Last Post: 8th August 2003, 08:07
