Monster MotorsportVolks Autos
    Shaq12's Avatar
    Drive it like its hot!
    Mar 2007
    Birmingham
    35
    Exclamation HELP - drivers side door won't open from the inside!
    Hi all,
    Not posted in this forum for ages but hope you might be able to save my life.
    Borrowed the girlfriends 09 reg TT roadster this morning to get to work. Unlocked the car on the drive via the keyfob, lights flashed, internal lights came on, heard the car unlocking BUT the drivers side door would not open from the outside. Passengers door opened fine and I could open the drivers door no problem at all from the inside. The drivers door handle outside is not loose, it still feels the same as the passengers one. Also if you put the key in the lock on the drivers door and turn it doesn't open the door either!
    I seem to remember a similar thing happening to a VW Golf I had years back but can't remember what the issues was and how I fixed it! So any ideas, suggestions etc. before I reluctantly have to take it to Audi... and/or confess what's happened!
    C
    A3 170 TDi Quattro S-Line
    Misano Red - Armrest with GSM Phone Prep - iPod Connection - MFSW - Heated Front Seats - Rear Parking Sensors - RNS-E - Cruise Control
    _________________________________________________
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    just tell her it was ok when you used it
    things go wrong
    or id take the door panel off and check in there.
  1. Driver's side door will not open from inside!!!
    By Sunbeam08 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 17th July 2012, 20:05
  2. Driver's side door will not open from inside!!!
    By Sunbeam08 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th July 2012, 17:37
  3. Driver's side door will not open from inside
    By Sunbeam08 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th July 2012, 08:21
  4. Driver's side door will not open from inside
  5. Left rear door won't open from outside
    By lscolman2 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th April 2011, 18:49
