Badger5Sky Insurance
Results 1 to 7 of 7
    Sep 2012
    Angry Tapping noise, worse when engine warm
    I've got a 2007 2.0tfsi FWD TT, engine code BWA.
    Bought it 6 days ago, its got an annoying tapping noise from the engine, also when sat on idle, it's very lumpy, but revs don't move.
    Been told the tapping could be the cam chain tensioner, that the tapping will be worse when oil is warm, and that it will only be lumpy when warm, which are the symptoms of my car but the garage said there are no problems what so ever. The issue with it being lumpy is getting worse each day.
    Highly annoying, but anyone got any clues to what it could be?
    Thanks !
    Feb 2011
    Falkirk
    309
    I'm assuming youve bought it from a garage. Take it back to them as they should have to fix it. Did you test drive before you bought it?
    I also have no idea what you mean by lumpy lol
    <img src=http://www.audi-sport.net/vb/image.php?type=sigpic&userid=54765&dateline=1406319799 border=0 alt= />
    warren_S5's Avatar
    Oct 2007
    7,166
    I've always thought the 2.0T was tappety.
    Your 'lumpy' idle may be cured by a change of plugs, but it's hard to say without seeing it.
    As said above I'd take it back and get it checked ASAP.
    Sep 2012
    I've took it back and they are claiming nothing is wrong with it, but the idle only does it when it's warm.
    Yeh i did test drive it, but i probably didn't hear the tapping because it had a belt squeak, which they sorted before i picked it up, along with the handrake. The idle was not at fault when i test drove it.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Well I have the same engine in mine and it smooth whether it's cold or warm... It does sound tappety, that's the way they are. It's the injectors that make the racket! It should be lumpy though and if it's only doing it since they sorted a belt squeak then it must be linked. Maybe the belt is over tensioned...
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    warren_S5's Avatar
    Oct 2007
    7,166
    Do knackered tumble flaps 'tick'?
    snapon's Avatar
    Jul 2012
    36
    Get the Car scanned with VCDS this should reveal stored fault codes relating to your idling problem and go back to the twat with a printout
  1. A6 2000 2.7t - won't start when engine semi warm
    By dan small in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd October 2013, 09:57
  2. Vibration at idle when engine is warm.
    By PhatBob in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th September 2009, 10:43
  3. Rattle/ tapping noise when idle.
    By jcp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th August 2009, 09:18
  4. Horrid noise when Engine returns to idle
    By Turbo Lag FTW in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th December 2007, 14:33
  5. loud blowing noise coming from engine when started up......?
    By rockstar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2007, 17:55
