EM TuningAH Fabrications
    Mar 2010
    Bristol
    48
    Old poster needs help!
    Evening all!
    Having left for pastures new (briskoda.net) I've found my way back here(!) and need someone to work out my riddle involving a MK1 TT rear brake calipers.
    I changed from my 8P A3 2.0TDI sport to a Skoda Fabia vRS and want to upgrade the rear brakes as they look lost behind my wheels.
    I know the rear setup from a 2wd TT will go on and have found someone with the 256mm rear calipers etc but he can't say for certain if they came from a 2wd TT, all he could say was that he tried to fit vented disks but wouldn't fit but the solid disc would....
    My logical way of thinking was the vented disc for the Quattro and solid disc from the 2wd, but that's a guess and have no idea really so I was hoping someone who drive them could help!?!?
    Cheers, J
    Feb 2011
    Falkirk
    296
    Hey,
    Im pretty sure you're right in your thinking. When I had mine it was vented disks on the back for the quattro. solid disks are for fwd tt as you can see if you check europarts or whatever.
    Dazz
  1. golf GTI 2.0 8V, playing up, need help!
    By Dr_Lokos in forum General Technical / How To
    Last Post: 26th August 2003, 18:11
  2. Need help fitting a CD changer cable
    By Kevint in forum In-Car Entertainment
    Last Post: 16th July 2003, 10:50
  3. Need help, can't take circuit board off Key!!
    By powersurge in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2003, 08:03
  4. Im new and need Help
    By WannabeRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd June 2003, 19:41
  5. Please I need help with spacers!!!
    By nianmuzik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 22:44
