JBSAMD Technik
    Jan 2012
    Post Thanks / Like
    Haldex Oil Leak (I Think) - Need Help
    Hi everybody. I'm new to this forum, and new to the Audi world. I am an owner of a 944 Porsche Turbo for 17 years now, and my wife decided that she wanted a sports car too, but more modern, so she chose the Audi TT225 HP Quattro Coupe. My problem is that I had the car parked in the driveway and I saw a little dot of oil on the ground (right under the cars rear), where the Haldex unit is. I jacked up the car, and I noticed a lot of oil around the unit, . I know its hard to tell . I already ordered the Haldex Oil Kit, but I would still like to know if any one you guys have ever had this problem before? it seems as if it is coming from the seal in between the Haldex and the shaft, but again, its hard to tell. Thats what probobly makes it spray all over the place. I put my hands on the filter, and it actually seems pretty dry. Thank you guys. I hope I'll get an answer. I don't want to put the new filter in with new oil, and still have the leak. Thank you.
    - Paul[ ][IMG]jpeg201-0312[/IMG]
    Jan 2011
    northants
    84
    Post Thanks / Like
    clean off with gunk or something then run car and recheck
    ive had them leak from gasket at side and driveflange seals
    Jan 2012
    6
    Post Thanks / Like
    with the sound panels off and rear jacked up you can see the haldex unit, plug uses lo!! torque and is easy to strip, lots of other drive parts there to eyeball as well
  1. Turbo Oil leak, Easy Fix? (Pics)
    By RyanGolfGTTDi in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2011, 15:26
  2. Haldex oil leak
    By talentwalsh in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2011, 14:13
  3. S3 engine oil, transmission oil, haldex oil, rear dif oil and front dif oil?
    By colicabcadam in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2010, 17:49
  4. Leak following Haldex oil change
    By NEiLS3LK51 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2009, 19:56
  5. haldex leak
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2008, 17:25
