TT magnetic ride
Gavin0478
Active Member
cleveland
Hi looking for a little bit of knowledge from you guys...
Looking at a new S3 (runs n hides) and thinking of spec'n the magnetic ride.
Problem is its rare on an S3 but standard on some tt's.
Is it a worth while feature but more importantly does it cause any issues if i lower the car.... can you remap the dampers so to speak to compensate etc?
Cheers Gav
I think both H&R & Eibach do spring kits that are compatible with MR, but it may be worth speaking to Damian at DPM to confirm.
id found that one but as its over 4 years ago id let it pass by lol
Hi Gavin,
Cant give you any advice re lowering, but my wife has the magnetic ride option on her S3. I actually find it very good, for the majority of running its left on the normal setting, but when you get a good section of twisting road and are in the mood to press on, the sport setting really firms up the suspension. It can be a bit jarring on really rough roads, but then you can always revert back to the softer setting. I would certainly add it to the spec list if I was planning a new one.
cheers
