My wifes tt has a funny problem, start the car and no faults reverse off the drive and the esp light comes on, turn the car off restart light goes out, drive a bit and then comes back on, no fault codes logged?!?
any ideas?
any ideas?
My tt did that and it was an abs sensor in the right front wheel you should check those. hope that helps
Brake pressure release solenoid - fault
mine is doing this
i think the Ross Tech website has a full list of fault codes you can compare against. not sure if there is one specifically for the relay but i wouldnt be say no for sure.
Dazz
