GNJJuicy
    The Original Scarface's Avatar
    No Ego
    Feb 2011
    Concrete Jungle
    313
    Post Thanks / Like
    19" BBS CK- offset 35 - Tires: 245/40/19
    I'm just about to buy a Audi TT 2.0T FSI and i wanted to know what wheels will fit on it. I love the 19" BBS CK's but im confused.com on what offset to get them in. I want the wheels to be parallel with the arches without rubbing but i haven't got a clue how the offset measure works on a TT because i know it's different on every car.
    Any replies appreciated.
    Cheers.
    Oct 2003
    up north...
    767
    Post Thanks / Like
    et 35 is too low - you should get away with et44 on a 245 tyre
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    No Ego
    Feb 2011
    Concrete Jungle
    313
    Post Thanks / Like
    Quote Originally Posted by dunk View Post
    Ok thanks mate. Is your TT et44? If so can you upload a pic so i can see what it looks like visually please?
    YT.
    Oct 2007
    SE UK
    34
    Post Thanks / Like
    ET35 should fill the arches nicely on the MK2, it will bring the wheel out flush, if you run a little stretch, like a 225 tyre then you will be spot on.
    I'm running ET 15 on the back of my Mk1 225 with 225 wide tyres and there's loads of room, could go another 5mm either side if I wanted..
    Mar 2004
    stonehaven/scotland
    12
    Post Thanks / Like
    guys, the TTS will run with a 52 offset with 19 x 9 alloys and 255/30/19 tyres
    Mar 2004
    stonehaven/scotland
    12
    Post Thanks / Like
    sorry, type error, the tyres will be 255/35/19.
    i have the original double spoke RS-4 style 19 inch alloys on our 2010 S-line, they are 19 x 9 ET52 with 255/35/19 ZR contis.
    They fill the complete arch with the lowered S-line suspension.
    the reason i know the ET is that i purchased other alloys and cold weather tyres, but went down to 18x8 ET48 with 245/40/18 tyres.
    The 18 inch look good, but the 19 inch look even better.
