EM TuningMonster Motorsport
+ Reply to Thread
    manor13's Avatar
    Aug 2013
    West of Lothian
    431
    HTML countdown timers
    I noticed HTML is switched to off when I tried to add a link for an external countdown that i wanted to add to my signature
    or have i done it wrong? I can see why advertising and all that, just wanted to make sure.Thanks
    2006 8P Audi A3 2.0 TFSI Quattro Sportback SE / 2013 8V Audi A3 1.6 TDI Sportback
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    The ability to post HTML (and any other markup/script/executable code) is heavily restricted for security reasons.
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
    manor13's Avatar
    Aug 2013
    West of Lothian
    431
    i thought that might be the case, it was just when i saw the globe linky thing in the signature edit.
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    That'll only allow you to post a link.
    You might find an image-based countdown timer which will work on the forum, it'll just be a bit less dynamic - i.e. it'll calculate time remaining and render an image to a static URL; it won't continue to count down after the page loads, but it'll at least show time remaining at the point the page loads.
    R
  1. timer/boost gauge
    By peteA3tdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2004, 18:51
  2. turbo timer harness
    By sisiu84 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2004, 23:30
  3. 2000 a4 turbo timer
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd January 2004, 00:57
  4. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
  • You may post new threads
  • You may post replies
  • You may edit your posts
