right, not tried these myself but according to the ross-tech wiki you can program drl's in vagcom
Central Electrics Channel 008: Daytime Running Lights
0 = Daytime Running Lights OFF
1 = Daytime Running Lights ON
I found this coding as well:
Module Central Electrical
xxx?x: Headlights
0 = Halogen Headlights w/o Daytime Running Lights (PR-8Q0/8Q1+8K0/8K7)
1 = Halogen Headlights with Daytime Running Lights (PR-8Q0/8Q1+8K1/8K3/9C6/9C7)
2 = Bi-Xenon Headlights with Daytime Running Lights (PR-8Q3/8Q5+8K9/8K4)
3 = Bi-Xenon Headlights w/o Daytime Running Lights (PR-8Q3/8Q5+8K0/8K7)
4 = Bi-Xenon Headlights with Daytime Running/Tail/License Plate Lights (PR-8Q3/8Q5+8K1/8K3)
i'll try it when i get home tomorrow :icon_thumright:
dunno i'd imagine it would be the sidelights but we'll find out
ok just tried it.
apparently my car doesn't have channel 008 on the central electrics module so couldn't do it through adaption so i tried it by changing the coding from 00001 = Rest Of World to 00002 = Northern Countries (Finland etc) and it worked.....but i have retro fitted oem xenons and they didn't like the new coding one bit
the sidelights & dipped headlights came on with the ignition but the xenons flickered then the drivers side went out and wouldn't come back on again. i reset everything back to original and the xenons were fine
so it can be done, and i reckon if i removed the xenons and re-fitted the standard halogens it would work.....but i can't be ***** with all that :icon_thumright:
Why do you think they work with halogens but not retro fit xenons then? Sounds a weird one.....
I think the US running lights is just front lights, but the Scandinavian setting will illuminate the tail lights too, is that right?
I thought it might be because my car doesn't have channel 008 so I couldn't tell it that xenons are fitted and then when I changed the country the coding wasn't correct as per equipment fitted.....maybe, maybe not, but I just can't bothered to swap the xenons out with the halogens just to try, lazy I know
I didn't check the tail lights, I was a bit busy sorting out the front end after the xenons started playing up :icon_thumright:
Thamks for checking. I have OEM Xenons. Neve simple is it!
Tought you had it solved. Damn
Are they factory fit xenons? If they are then you should be able to program the DRL's through the adaption channel rather than changing the coding. I think mine don't work because, although they are oem xenons, they weren't factory fitted so the module that controls them wasn't programmed to control xenons, i think this is why my module doesn't have channel 008 on the central electrics module.
I wouldn't give up trying to do it this way. Try and find someone near you that has vagcom or vcds as its now called and give it go :icon_thumright:
on ebay you can buy r8 look ones for bout £20 and fit them in your head lights on a sep switch or like me i've put them in my bumper on my b5. they are only a strip of led's
maybe but not round here. but still they only look rite on an audi. i mean how out of place do they look on other cars at least they were ment for our cars not ford vauxhalls pugs etc.
