i have a 1.8t quattro which has had ia fault for sometime now,when the car is driven hard it 9 times out of 10 starts to pulse at high revs in gear,just like the turbo is backing off and then coming back to life,you can even sometimes get it to missfire,car runs fine apart from that,have posted on here before but no one had a DEFO fix,i have tried things like coilpacks,n75 valve,dumpvalve,plugs,check for fault codes,and all the other checks,anyone had the same fault as mine and have found the fault??
cheers
cheers
