JamS3 said:Whats the differences mate with the 0600 s/w to the 0550 s/w?
Fantastic. So we'll have to wait for 0650 or 0700 now! Has it sorted the locking up issue? I suppose you'll have to run with it for a while until it happens again.a3norwich said:Nope. Doesn't sort the shuffle problem out. Rubbish!
a3norwich said:Not locked up since I upgraded (Monday)
It can be done, mine sometimes locks when I try to switch from Nav info to map view ....JohnS3 said:Been running it for a week now and it's not locked up yet....
a3norwich said:Shuffle problem is now fixed in S/W 0650! WOO!!!
JamS3 said:How long has this firmware been out?
Twizzler said:Where is the 2008 maps dvd available from? My supplying dealer says 2weeks to 2 months. My local dealer says 200 2007 dvds are to be shifted before the 2008 dvd is rolled out!
Second that - I got mine in December from a contact in Belgium.Issac Hunt said:They are talking crap - speak to another Audi dealer if you want to purchase one, or get one from Ebay or elsewhere online.
Twizzler said:The local dealer checked his computer and told me the only one listed in the UK currently is the 2007 version. He said he would need to make a phone call to ascertain the position. He then came back after a while to say there were currently 200 in the system to be shifted before they could supply the 2008 ones. This seemed to tie in with the supplying dealers rather vague e-mail to me in which he said it could be 2 weeks or 2 months ie -depends how fast the 2007s go presumably.
MarcQuinlivan said:downloaded and applied 0650 with the SDS mod today. Seems to be a bit more stable than 0600.
I have the altimeter too, but apart from that I can't see any major differences.
you male or female......Slinger said:...if they wouldnt mind doing me a copy and I would make it worth their while
Sound advice. During the update, the progress bar can sometimes remain still for a long period - you just have to leave it alone and sweat it out!MarcQuinlivan said:Turn on your RNS-E, eject the navigation disc, insert the new disc, close the door and it should start the update. if not you may need to change out of the navigation screen (into radio\cd), insert the new disc, close the door and then press the NAV button. The screen should then say "updating". It will run through, reboot, and show the updating screen again, then when it is finished it will power off. When you power it back on it will ask you for the navigation DVD. Do not turn the RNS-E off or remove the key from the ignition while the update is in progress as your unit may not function properly afterwards.
Issac Hunt said:Or get the SDS hack pre-applied to the .kwi file from Here
MarcQuinlivan said:you male or female......
rickquattro said:Issac, got the file downloaded from your post link, its a zip file, whats the next step and what is SDS....
Thanks (hopefully), for your help... I think that my software is the first release with the enabled TMC...
MarcQuinlivan said:you'll need to extract that zip file and burn the contents to a dvd
Correct. Even with all the SDS files the SW update is less than 30MB.Issac Hunt said:No need to waste a DVD, a blank CD will be fine. The file size is only something like 40 megs.
