john2garden said:
I had a problem with mine I posted a thread on it. Andy Mac got it spot on and said it was the blower. Have a look at this -
Thread
Link doesnt work
I have a problem with my Audi B6 also, the fan blower keeps shutting off intermitently, I will try and explain..
It started at Xmas time, the cold weather came and every now and again the blower would not come on, but when the temp outside was above 14c it would work perfect, now slowly the temp is increasing, and the fan wont come on at all now unless the car is in direct sunlight at 25+c.
Is this the strangest thing you have heard haha???
I have a VAGCOM and no codes reported, I have checked sensors, water levels etc all fine, I have removed the CLimate unit and cleaned it and since doing so it got worse, and now rarely comes on.
The display is showing full blower but no air is being blown, to throw another spanner in the works, if I remove the 30 amp fuse from the fusebox and replace it(3rd down from top) the blower comes on for 15 secs then shuts off.
Also if the blower does come on on a hot day, it will shut off after 20-30 mins, then if I press off on the climate unit and switch is back on after 30 secs it comes on again for 2-3mins ( nice cold air)
Anyone have ideas?
Faulty Climate control unit is all I can think off?
