Oil leak - Recommended Torque setting?
SCHOLESY83
I have a leak from what looks to be the base of item 6 in this diagram - from my research it's apparently common. I was gonna try nipping up the M6 x 22 socket head bolts first. Any recommended torque settings?
cheers.
ft or fft (farmer tight) or well you can guess the next , it wont hurt to do it fairly tight i mean just nip them up a 1/4 turn more than they are now by the sounds of it the gaskget is goosed
I see, do you know if it is easy enough to change this gasket, or am I best putting into garage, I'm no mechanic.
