i need some 8mm spacers for a b8 with a 66.6 bore where can i get some but uk only
hades- Well-Known Member VCDS Map User Joined Jul 8, 2008 Messages 9,420 Reaction score 641 Points 113 Apr 20, 2014 #1 i need some 8mm spacers for a b8 with a 66.6 bore where can i get some but uk only
A A4sportMrT Registered User Joined Oct 4, 2013 Messages 268 Reaction score 22 Points 18 Location East Sussex Apr 20, 2014 #2 Do you need 8mm spacers or could you fit 5 or 10mm, because there are loads of them on eBay
hades- Well-Known Member VCDS Map User Joined Jul 8, 2008 Messages 9,420 Reaction score 641 Points 113 Apr 20, 2014 #3 A4sportMrT said: Do you need 8mm spacers or could you fit 5 or 10mm, because there are loads of them on eBay Click to expand... most of the ones on the bay are from outside the uk abd 15 quid postage
A A4sportMrT Registered User Joined Oct 4, 2013 Messages 268 Reaction score 22 Points 18 Location East Sussex Apr 20, 2014 #4 http://www.ebay.co.uk/sch/i.html?_sacat=0&_from=R40&_nkw=66.6+spacers&rt=nc&LH_PrefLoc=1 Loads available and in the Uk, or failing that a local machine shop should be able to knock you a set up
