Forge MotorsportAdrian S Flux
Results 1 to 12 of 12
    May 2007
    15
    Post Thanks / Like
    RNS-E, Iphone contacts??
    I successfully connect my Iphone 3G 8GB to the RNS but I only see my contacts in the FIS and not on the “telephone” menu on the RNS. Should I be seeing them there as well ?
    Does anyone know why I do not see them? Do I need to vagcom something ?
    Jan 2004
    York
    1,639
    Post Thanks / Like
    I assume your using the Audi BT kit and not something like fiscon ?
    Going ..... '56 Audi A4 2.0 TFSI Sline SE quattro Avant
    To be replaced by a
    11 plate SEAT Exeo CR ST Sport Tech
    May 2007
    15
    Post Thanks / Like
    Fiscon ?
    I have the original audi bt system, I only see contacts in fis and can call threw fis with my steering wheel
    Jan 2004
    York
    1,639
    Post Thanks / Like
    Fiscon is an aftermarket kit than emulates the Audi BT kit (quite well in my experience). I went with the fiscon kit in mine as I've heard that iphone support with the Audi kits is patchy at best. Do you know what revision your BT kit is ?
    To be replaced by a
    May 2007
    15
    Post Thanks / Like
    no i dont know that, is there any way I can find out ?
    Jan 2004
    York
    1,639
    Post Thanks / Like
    If you have access to vagcom you can scan the controller and it will give you the information. Otherwise it's a case of stripping out the car to get to the where the bluetooth module is installed and look at the part number on the metal box. If it's a factory fit module it's under the drivers seat (under the carpet)
    As far as I'm aware you can't flash upgrade the software on the BT module. So the only way to get "better" phone support is by replacing the module it's self. However it may just be a setting you have to configure on the phone or the rns-e to pull over the phonebook. I'll have a look at my rns-e manual tonight.
    To be replaced by a
    comc's Avatar
    VW-7 Audi-1
    Edinburgh
    48
    Post Thanks / Like
    I recently retro fitted the RNS-E to my A4 which had the audi bluetooth phone prep from new (2006 MY). I use a 3G Iphone running 3.1.2 firmware.
    After the install, and before sorting the VAGcom coding, the RNS-E would not sync any of my contacts on the TEL function. My phone was correctly syncing with the audi bluetooth and showing my contacts on the DIS. Another thing that was missing from the RNS-E was the little bluetooth icon on the display to tell me that my phone was connected. I was however still able to answer and end calls through the RNS-E controls.
    After Vagcom coding the RNS-E to tell it that the Audi Phone Prep was present in the car, the RNS-E now syncs all contacts and call history with my Iphone and everything is now correctly displayed on the TEL screen and the Bluetooth icon is now present.
    I would recommend correcting your coding through Vagcom and then see if it works.
    2006 A4 Avant 2.0 TDI (140) S-Line
    Phantom Black
    Audi Phone Prep, Bose, retrofit RNS-E, rear Parking Sensors, rear Sunblinds, Canbus friendly LED sidelights
    Jan 2004
    York
    1,639
    Post Thanks / Like
    Yup agree. Should have thought of that before. I just assumed it had been coded.
    To be replaced by a
    May 2007
    15
    Post Thanks / Like
    Great thanks!!
    Do you remember where you found the code or where in vagcom ?
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,058
    Post Thanks / Like
    open vagcom and go to telephone ( 77 ) i think once opened the code will be there adjust accordingly with the drop down hints
    LOTS DONE, LOTS SPENT !!!!
    comc's Avatar
    VW-7 Audi-1
    Edinburgh
    48
    Post Thanks / Like
    ....alternatively click this link
    http://wiki.ross-tech.com/wiki/index...mon_Procedures
    and then select your Audi variant......I found it easier to spend a bit of time reading through the information on my laptop before plugging the car in.
    Phantom Black
    Sep 2008
    40
    Post Thanks / Like
    How do I change the BT module to display the 1st name & then the last....at the moment it's showing the last name first...and before you say change on the phone thats done already...anyone know something
