AMD TechnikBadger5
    Post Thanks / Like
    Internal RNS-e pics required
    Hi, I purchased a used RNS-e on eBay and typically the unit that was described as in mint condition and fully functional has a broken dvd drive. Strangely enough, the seller also forgot to send me the navigation disc. hmmmm
    Anyway, I have taken the top off and found a little piece of plastic sitting on top of the broken drive. My guess is that the mechanics of the drive have broken and if I can find the home for this little piece of plastic I might get it to work again.
    My problem is that I dont have a reference to compare the drive to.
    If anybody could post some very close up shots of the rns-e internals, that would be great.
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    437
    Post Thanks / Like
    I take it you lodged a complain with Ebay, and are trying to get your money back?
    If your drive is broken, then you will need to replace it. There are two members of www.audiforum.us who can help. send a PM to rabbit or haggiee, these two guys will sort you out with a replacment, and also send you a DVD.
    A6 Avant 2.7 TDI S Line (C6)
    MMI 3G
    RS6 LED headlights with AFS
    LED Tail lights
    Auto dimming rear view mirror
    Privacy Glass
    Engine re-map 45PS & 100nm extra
    Winter Pack
    Flat Bottom MFSW
    Rear view camera
    Post Thanks / Like
    Yeah, I'm trying for a refund but looking at worst case scenario. I f I am stuck with it, I would like to try and fix it rather than have wasted £400 on it.
    Jan 2004
    York
    1,639
    Post Thanks / Like
    Which seller did you buy it from ? I've had the exact same issue, and both units I got we're knackered. Luckly the replacement unit the seller sent out was cheaply fixable (just needed to replace the facia) the first one though was a drive fault and I sent it back as a new drive was too expensive.
    Ebay didn't want to know. I raised a paypal claim but they just said send it back (again !) at my expense. The facia purchase was cheaper than sending it back.
    Going ..... '56 Audi A4 2.0 TFSI Sline SE quattro Avant
    To be replaced by a
    11 plate SEAT Exeo CR ST Sport Tech
    JohnS3's Avatar
    Oct 2004
    3,022
    Post Thanks / Like
    jisumfish's Avatar
    4 Spring Duck Technique
    Jul 2007
    West Midlands
    72
    Post Thanks / Like
    That link appears to be broken ^?
    Try this one http://audiforum.us/sale/8027-sale-l...ace-laser.html
