Sky InsuranceChris Nott
Page 1 of 2 12 LastLast
Results 1 to 40 of 42
    Jun 2007
    Yorkshire
    307
    Fitting of RNS-E to new A3 8P Black Edition
    Hi guys--
    I've just ordered a new 8P Black Edition which comes as standard with the double DIN Concert headunit (Concert III ?)
    I'd like to retro-fit the RNS-E as I didn't fancy the crazy pricetag on the Audi options list, however, I'm not entriely confident I won't make a ****** of it (especially doing it in a new car), plus I'm unsure if I need the "Chrome Version" of RNS-E or if I'll need VAG-COM to do any coding (which I don't have).
    Any recommendations of how to get it fitted if I source the bits? I'm in Leeds, West Yorks and would appreciate the advice. Would I be right in saying if I source the parts then the supplying dealer wouldn't be able or wouldn't want to fit RNS-E for me as it requires harness adapters (from kufatec.de)? I presume I'll need this as I've spec'd the car to come with Bluetooth+iPod Dock+Bose?
    Apologies for the questions but I've read through the FAQs and can't find any reference? Also - will I need the Chrome version or not.
    jisumfish's Avatar
    4 Spring Duck Technique
    Jul 2007
    Hampshire
    74
    Have a read of this http://www.audi-sport.net/vb/showthr...t-nav-Retrofit it will you abetter understanding of whats involved - if you've got double din then it's very easy
    Jun 2007
    Yorkshire
    307
    I've had a read of that thanks -- though I'm still unclear as to the need for VAG-COM coding (though this guy suggests not) and how to maintain compatibility with the iPod, Bose and Bluetooth.
    that, and I am very concerned that I might make a cock up of it!
    Apr 2009
    Shirley, Solihull
    542
    drop s8craig a pm. this is his website...
    http://www.tclsatnav.com/index.html
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    Jun 2007
    Yorkshire
    307
    Thanks for the tip, anyone else used s8craig's services? I emailled Kufatec about my config (for an adaptor) and they said they were unable to help. Agh! It looks like it's going to be a lot harder than I thought to accomplish this mod. I've also seen reference to "moving pins" to keep my BOSE working as well.
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,424
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    I dropped a brand new RNS-E into my 59plate and had no issues what so ever. Everything worked fine and required no VAG-COM. Only thing i had to do was change some of the pins for the BOSE and the aux.
    Jun 2007
    Yorkshire
    307
    Quote Originally Posted by Cruiser89 View Post
    That's good to hear - how did you find out what pins needed to go where etc? Do you have bluetooth as well?
    JohnS3's Avatar
    Oct 2004
    3,021
    Hi Dan,
    If you have BOSE you need to move the BOSE pin, move the aux pins into the rnse av connector (you need to buy one from Audi) code the unit properly and the car too. I have VCDS and am not too far away from you. I could even do it for you if you like (beer tokens accepted!!)
    You may also want to mod your antenna system if you have degraded FM reception. There's a long post on that on here, vagoc.co.uk and audiforums.us
    Jun 2007
    Yorkshire
    307
    Hi John, thanks for the offer! I might just have to take you up on that (I'm always a fan of beer tokens myself)
    I can't find any more info anywhere on moving the BOSE pin, you're also the first one to tell me about the RNS-E AV Adaptor. My google skills and forum searching isn't doing me any favours!
    Dan
    (Sorry for delay in getting back to you, been away a few days)
    JohnS3's Avatar
    Oct 2004
    3,021
    Bose pin move as follows...
    JohnS3's Avatar
    Oct 2004
    3,021
    If you want to keep the AUx inputs then you'll need one of these...
    Jun 2007
    Yorkshire
    307
    Ah, makes more sense already! Where are you based mate?
    JohnS3's Avatar
    Oct 2004
    3,021
    PMd
    Hi all
    I have installed a RNS-E 2008 retrofit into my 07 S3, replacing my Concert 2, and my BOSE sounds fine ? Do I still need to move the BOSE pin??? I also haven't had any Vag Com coding applied??? Literally plug and play???
    Anyone advise????????
    JohnS3's Avatar
    Oct 2004
    3,021
    I'd advise move the bose pin, code the car and code the unit for the options on your car. In my mind this is the only way to do it.
    Other may tell you to leave it as it works, but it's your call, it's your car.
    Any one in London area fancy doing this for me in exchange for beer tokens as I have no clue how and dont want to risk really messing something up? I am hopeless with computers and sure this would take someone 10 minutes compared to the 3 weeks it would take me
    Apr 2010
    West Midlands
    13
    How did you get on fitting the satnav? I own a new 8P Black Edition which comes as standard with the double DIN Concert II with bose sound. Just got a RNS-E from a 2009 with the hope of doing a DIY fit. Any advise, hope all that is needed is to change BOSE pin No.5 pin to No.7? JOB DONE, or is it?? Any advise would be helpful.
    27,028
    Your antenna system will be incorrect for the rns-e so radio stations may suffer sometimes, but overall its almost plugnplay but I strongly advise a vagcom scan.
    AJSOMER did you get it fitted or still need someone.
    Jun 2007
    Yorkshire
    307
    I can't be of much more help at the mo, andy, as I'm still waiting on the arrival of my motor (I asked preemptively) but the lads on here especially Nhn know their onions. It'll be mod no.1 straight out the door when I get it.
    Apr 2010
    West Midlands
    13
    Not fitted yet, maybe someone will help me with this, as I have no idea with vagcom? I was hoping it would just a pin change.
    27,028
    I have a mate whose in Coalville who will help, if you're happy to goto him as him coming to you will cost you more, I'll ask him to PM you.
    OK sent him a message, he'll PM you as soon as he sees it.
    Apr 2010
    West Midlands
    13
    Thanks mate, I would appreciate this.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    andy, you have pm mate happy to help
    LOTS DONE, LOTS SPENT !!!!
    Apr 2010
    West Midlands
    13
    What parts do I need to get to have the correct antenna system?
    JohnS3's Avatar
    Oct 2004
    3,021
    Quote Originally Posted by andyjlee View Post
    000 098 652A 1.5m female to female Fakra cable (you can get away with a 1m cable, 000 098 652) (12)
    000 098 692 30 cm male to male Fakra adaptor (12)
    8P4 035 225B Upper antenna amp (14)
    8P4 035 225 Lower antenna amp (150)
    1C0 973 119B Three pin connector housing x2 (1.50 each)
    000 979 009 Repair wires x3 (1.20 each, cut them in half to give 6 wires)
    Covered here in detail...
    http://www.audi-sport.net/vb/showthr...-use-with-RNSe
    27,028
    The very man to advise on the antenna system, cant get better than John.
    Afternoon John.
  28. #27
    Apr 2010
    West Midlands
    13
    All this antenna issues are putting me off installing the RNS-E, it think I will install it and see if I can live with the degraded FM reception before updating the VAGCOM. If the poor reception becomes an issue, I think I will put the concert III back in?
  29. #28
    Apr 2010
    West Midlands
    13
    Did you have antenna issues (poor FM reception) after installing your RNS-E unit? I have a 10plate with Bose and ipod, all this antenna issues are putting me off.
  30. #29
    27,028
    TBH mate there are a load of members with rns installed using the wrong antenna system & they seem to be ok with it, just install & if it bothers you update the antennas, the difference in use of the 2 units is fairly substantial, feature list is far superior with the RNS, I can assure you, you wont go back to concert once rns is in.
  31. #30
    JohnS3's Avatar
    Oct 2004
    3,021
    Afternoon John.
    Morning!
  32. #31
    27,028
    Yeah & what a morning so far, but the client paid the bill so success today, it was that or loose there email/efax systems at midnight lmfao
  33. #32
    Jun 2007
    Yorkshire
    307
    That's always a good motivator to make a client get their cheque book out!
    Ibis white 2010 A3 2.0TDI Black Edn.
  34. #33
    Apr 2010
    West Midlands
    13
    Do I need one of connector to keep my ipod working, or is this just for the aux stocket?
  35. #34
    Apr 2010
    West Midlands
    13
    Sorry, two kids playing up during this. Just need to know will I need a 32-pin female B6/B7 cluster connector block to keep my ipod working?
  36. #35
    Apr 2010
    West Midlands
    13
    Quote Originally Posted by 1wheelonly View Post
    Hi mate, satnav arrived today, but still waiting for removal keys and antenna cable. Are you still on to set the vagcom when fitted?
  37. #36
    27,028
    He has keys & I have an antenna cable I can send to him as in gps I assume or did you order these bits already, also are you installing it or is he?
  38. #37
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    just replied to your pm, if you want, ive got keys and we could use my antenna etc to fit yours and get you coded and all up and running.
  39. #38
    Apr 2010
    West Midlands
    13
    Hi,
    Spoke to guy on the phone and he is very confident in getting the pin code, all being well I shoud have the satnav fitted mid week. However there are few questions I still have which you may be able to help me with.
    1. Where is the best place to locate the gps antenna on the 8P model, there is no room back of the clocks?
    2. I need to relocate wire 5 into 7 for bose, but if there is a wire in 7 were do I locate this as I need to tken this out for the bose wire?
    3. If all is working OK after the install, why do I need to have the unit setup & coded using VAG-COM?
    4. If I fit the unit OK, and what the RNS-E coded using VAG-COM, what would be the cost for you to code the unit with the car?
  40. #39
    27,028
    GPS antenna stuck to the dash above glovebox of course hidden.
    You need to check what the spare wire was before you moved it to see if its detrimental & if it needs to be moved itself to another location.
    Vagcom is always suggested to make sure there are no untoward faults arisen from the install & to properly code features on the unit & associated modules, do as you like but I would always suggest a vagcom scan when installing these units.
    You need to ask the coding person directly via PM what the cost would be, not on the open forum as its a personal deal.
  41. #40
    Apr 2010
    West Midlands
    13
    On the concert 3, block C, pin 7, it is marked K-LTG (is this the K-Line?). If I do not move this pin it will go to the RNS-E, block C (Mic In +) is this correct. Or should I move it to block B, pin 5 marked K line? Sorry for all the questions.
