Hi There,
I have a few problems with an upgrade.
I recently fitted an 09 rns-e. I already had factory fit BT, and retro fbmfsw.
The bt would pair with the rns-e, but would not display tel numbers/phonebook etc.
After a bit of fishing around on here, it seemed apparent that my bt module was to old, (d version) So i bought a new s version to upgrade to.
As i was going to be ripping the seat out etc to access the module, I decided it would be a good time to do the sds mod aswell.
However, now i have problems.
I cannot get the sds to work (no beep from steering wheel)
And the phone book is still not being displayed.
I can make and receive calls, But there is a slight buzz on the line . (it isnt as clear as it was with the old unit)
Could anyone point me in the right direction for finding the problem?
My coding is as follows
instrument 0004443
nav 0205715
tel 0011420
wheel 04022
Sw 660 ~(for sds )
following error codes
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Control Module Part Number: 8E0 035 192 T HW: 8E0 035 192 T
Component and/or Version: RNS-E HIGH EU H74 0690
Software Coding: 0205715
Work Shop Code: WSC 00441 210 88110
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Mileage: 134908 km
Time Indication: 0
Date: 2010.01.14
Time: 12:09:19
Freeze Frame:
Bin. Bits: 10110011
Bin. Bits: 00
Sunday,24,January,2010,12:19:17:65047
VCDS Version: Release 908.1
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Mileage: 134908 km
Time Indication: 0
Date: 2010.01.14
Time: 12:15:05
Freeze Frame:
Bin. Bits: 10110011
Bin. Bits: 00
Sunday,24,January,2010,12:20:01:65047
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Control Module Part Number: 8P0 953 549 C HW: 8P0 953 549 C
Component and/or Version: Lenksäulenmodul H21 0050
Software Coding: 0004022
Work Shop Code: WSC 06314 000 00000
Additional Info: XXXXXXXXXXX Lenkradmodul H06 0030
Additional Info: Geraet 00000
1 Fault Found:
004 - No Signal/Communication
Any help greatly appreciated
instrument 0004443
nav 0205715
tel 0011420
wheel 04022
Sw 660 ~(for sds )
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Mileage: 134908 km
Time Indication: 0
Date: 2010.01.14
Time: 12:09:19
Freeze Frame:
Bin. Bits: 10110011
Bin. Bits: 00
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Mileage: 134908 km
Time Indication: 0
Date: 2010.01.14
Time: 12:15:05
Freeze Frame:
Bin. Bits: 10110011
Bin. Bits: 00
1 Fault Found:
