Chris NottVolks Autos
Results 1 to 13 of 13
    stevehall's Avatar
    Aug 2008
    Littleborough, Lancashire
    298
    Current RNS-E Firmware
    What is the current release of firmware for the RNE-E?
    I want to know if mine is up to date? - If not how can i update it?
    HW: 8E0 035 192 T
    Component: RNS-E HIGH EU H75 X---
    Revision: 06S
    I also notice I have HIGH in the component detail off VAG-COM what does that mean?
    Steve
    ___________________________
    Audi A4 Avant B7 2.0T FSi Quattro
    Done: | Ambient Light | 18" Audi RS6 Alloys | Westfalia Detachable Tow Bar & ECU | De-Egg | RNS-E | Bluetooth Kit | RS4 Anti Roll Bar | Audi Torch | Full Rear De-Badge |
    To Come: | Audi A6 3.0TDi Le Mans - When I can find the right one!|
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    If you are runnig a 2009 DVD, then you should have the latest Firmware version. There are some hacks available to activate SDS and VIM (650)
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    stevehall's Avatar
    Aug 2008
    298
    Thanks for reply.
    Where can i get the hack? i want to use VIM for a multi media input
    Steve
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    as far as im aware you have to downgrade the firmware first to activate the VIM and then update, i may be wrong but 99% sure this is correct
    LOTS DONE, LOTS SPENT !!!!
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    When that X-- is showing in the RNS-E it's a good sign that someone has half hacked the software for SDS.
    Really that should be displaying 0650 for the latest software.
    I set the units for downgrade using channel 97, then run the 2005 version 0100 software, you can then hack the the SDS and VIM correctly back up to 0650 and as that is the last ever software it wont be over written.
    Apr 2006
    england
    754
    when i go in car setup and version this comes up
    SW: X---
    HW: H74
    Map: 8P0919884_AA_EUW
    can someone tell me why SW is showing "X---" instead of numbers,
    but all in all the rnse works perfect, just wondering why it shows that
    many thanks
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Did you read the post above....
    Quote Originally Posted by khalil View Post
    SW: X---
    HW: H74
    many thanks
    Jul 2009
    10
    I just noticed this thread and have a question about the SW X ---- showing up.
    My newly retrofitted 2005 RNSE is also showing the SW: X ---
    I put a genuine Audi 2007 DVD into my RNSE, and it stayed at X ---, I then downgraded using channel 97, the 2007 disc then loaded up again but the SW code stayed as X ---.
    So how do you get rid of the X --- and get the current software to load?
    Phil
    Apr 2009
    Shirley, Solihull
    542
    Quote Originally Posted by Phradge View Post
    Phil
    Thanks Phil you've just saved me 20 minutes sitting in the cold as I was about to go out and do this with mine!
    I have read that the only way round these is a new motherboard???!!
    If any of the guru's have any more info I'm sure we'd all be very grateful for it
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    Jul 2003
    Berkshire
    34
    My RNS-E was also set to version X-- and it always bugged me that I didn't know exactly what version it was! Mind you, I never realised it could be a good thing with an SDS mod.
    One quick check you can do is to see if Altitude is shown within your Nav Satellite details. I believe this was only brought in from version 0650 so if you see Altitude shown then you're on the latest version (or a hacked equivalent)
    For me, I followed the same steps as Phil, downgraded the version via VCDS and for some reason (can't remember why) it took 2 attempts to work but on my 2nd attempt it correctly installed 0650. Note: that I was installing 0650 from a dedicated 0650 software upgrade CD and not from a Nav DVD.
    So it can definitely be done - no motherboard change required.
    Hope that helps
    Jul 2009
    10
    Just checked my unit in Engineering mode (press NAV, then top left for 10 secs, then top right till screen changes) and it is definitely 0650 or 0660 as I have both the altitude and the SDS showing as active.
    Apr 2009
    Shirley, Solihull
    542
    Checked mine today and it is showing altitude and sds so I'm gonna leave it alone!!
    20
    I see that I have SDS but no sign of altitude ..is this not up to date ?
