EM TuningMonster Motorsport
Results 1 to 9 of 9
    Living a little!
    London
    181
    RNS-E Centre Dash Screen?
    After testing the install this evening I noticed in the centre dash it gives you the street road etc. Very clever, I like! But...
    My question is... I used to get the other info on the car. Mileage of fuel left, MPG average etc.
    Is this not an option of having now the RNS-E is installed?
    david_phillips95's Avatar
    Nov 2008
    538
    you just need to use your stock for controlling the DIS and you can flick through the screens as normal
    Davie
    Living a little!
    London
    181
    Quote Originally Posted by david_phillips95 View Post
    Davie
    Wouldn't work. It was staying the same and says S for south or whatever direction your going and the street name.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Turn off compass mode in the NAV setup
    Nov 2008
    538
    Quote Originally Posted by karbonk View Post
    I was out in mine the other day with the NAV running and it let me change screens, yours must be setup different to mine.
    Davie
    Apr 2009
    Shirley, Solihull
    542
    you need to use the button on the underside of the stalk, the one that changes from memory1, memory2, off etc
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    as above, button underneath, turn off and back on
    LOTS DONE, LOTS SPENT !!!!
    Living a little!
    London
    181
    Quote Originally Posted by 1wheelonly View Post
    You mean the reset button? Im sure I tried that but will give it another go in the morning. Thanks all for your comments.
    Living a little!
    London
    181
    Yep tried the reset button today and works now, not sure why it wouldn't work first time round. Allows me to cycle through as normal now. Cheers
