Hi guys, I have a problem
I have A4 cab and have RNS-E with VIM hack and SDS Hack
SDS has been working great until I have just install OEM bluetooth
The BT device has Voice Control coded off control via RNS-E
When I code the RNS-E for BT - SDS does not work
I have 2 mic's one i had for the SDS wired into the RNS-E and the other with the BT kit (wired into the BT kit).
If i activate the BT voice Control i can use it no problems (but this doesnt control the RNS-E obviously).
If i recode RNS-E to think there is no BT then reset i can use SDS again, if however i use my phone the BT device uses the system and then SDS doesnt work again, until i rest RNS-E.
I know that people have wired one mic to both RNS-E and BT , and some have wired to the RNS-E and then use mic outputs to the BT mic input (daisy chain)
This would indicate that you could really use 2 seperate mics, right?
Anyone have any ides why my SDS wont work when coded to BT?
BT coding - 0011702
RNS-E coding -0413117 without BT coding
0413717
Thanks in advance
BT coding - 0011702
0413717
Thanks in advance
