Sky InsuranceEM Tuning
    a3_dan's Avatar
    Aug 2009
    South London
    588
    Symphony II to RNS-E Adapter cables...
    Just bought an RNS-E (Thanks Mitch78) And now need the adapter cables for my symphpniy II, Anyone know if these would do the trick?
    http://cgi.ebay.co.uk/AUDI-RETROFIT-...item2a02d874ed
    Or is it best ordering from Kufatec?
    Dan
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    You tend to find this is a general purpose cable set, is your car BOSE? I find 2 things wrong with these harnesses.
    1. Front speaker wires are transposed L to R opposite to the rears. Not a problem if you have BOSE.
    2. BOSE wire is missing and needs to be added to pin 7 of connector B, not a problem if you do not have BOSE. But see above.
    a3_dan's Avatar
    Aug 2009
    South London
    588
    Hi Craig,
    Thanks fo the reply.
    In response to your question, yes my system is a Bose system.
    I just went and bought this instead now:
    http://www.kufatec.de/shop/product_i...nlock-key.html
    What do you think?
    I did specify it was Bose when ordering, so will I need to do any Pin adjustments?
    Many Thanks,
    Dan
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No Kufatec are usually spot on.
