Sky InsuranceChris Nott
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,572
    Car Computer & RNS-E
    Hi all,
    Ive been doing research into installing a computer into a car, but I would only go ahead with it if I could hook the computer up to the RNS-E screen.
    I know that there are 'RNS-E Multimedia Adapters' available on eBay that allow RCA connectors to be plugged in, which I'm assuming would follow the same concept as plugging a scart lead into a TV?
    I've searched on eBay and have found some VGA to RCA cables:
    http://cgi.ebay.co.uk/VGA-to-3-RCA-C...item3ef9563bca
    I was hoping someone who knows about this kind of thing could let me know if this would work okay?
    Thanks for any help,
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    One issue you have is fooling the RNS-E into thinking it has a TV tuner attached, basically unless the RNS-E sees a TV tuner on the canbus, then you will not be able to select the TV input.
    Also, the RNS-E uses RGB and sync seperate, so RGB alone may not be enough.
    Have a look on navplus.us, one of the guys on there has connected a PC directly to the RNS-E and got the resolution right.
    http://audiforum.us/multimedia/2144-carpc-project.html
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,572
    Thanks for that mate, Ill have a browse.
