Chris NottMonster Motorsport
Results 1 to 1 of 1
    Jul 2013
    10
    Rns-E A3 Early 2006 Aerial Issues
    Hello
    I have just fitted the double din cage to my A3 for an RNSE having come from a single din Concert ii.
    I then did a scan with Vag-Com to see if things were all dandy and came up with an interesting code that is not the usual ZF short to ground issue that a lot of others seem to be having.
    I have the Single fakra and Black ISO aerials and am experiencing severely degraded radio reception.
    Saturday,16,November,2013,17:47:35:45558
    VCDS Version: Release 11.11.6 (x64)
    Data version: 20121223
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 76 7D
    VIN: WAUZZZ8P16A147818 Mileage: 161160km/100140miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
    Component: RNS-E HIGH EU H73 0550
    Revision: 02S Serial number: AUZBZ7G1100609
    Coding: 0215351
    Shop #: WSC 02197 785 00200
    VCID: 3261F556AD9E9788E6F
    2 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 161164 km
    Time Indication: 0
    Date: 2013.11.16
    Time: 17:36:03
    Freeze Frame:
    Mileage: 161160 km
    Count: 1611
    Clock: 17:35
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 161164 km
    Time Indication: 0
    Date: 2013.11.16
    Time: 17:36:13
    Freeze Frame:
    Mileage: 161160 km
    Count: 1611
    Clock: 17:35
    Would greatly appreciate any help on how to fix this!
    Cheers Ricky
  1. Retrofitting latest RNS-E and Bluetooth to 2006 A3
    By satj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2012, 17:43
  2. Audi S4 (2003) Diversity Aerial issues??? HELP PLEASE!!!
    By Lion Heart in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th December 2011, 13:38
  3. S6 5.2l V10 aged 2006 + known issues etc
    By Simon S4 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 16th October 2011, 23:46
  4. Upgrade To rns-e 2010 model in 2006 Model Audi Bose pin change?
    By Dannykn9 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th June 2011, 14:33
