EM TuningAH Fabrications
    Oct 2013
    A4 B7 sat nav issue
    Hey guys,
    new member and just looking for a bit of advice.
    This is also posted in the A4 B7 section.
    recently my sat nav has stopped working.
    I put the cd in and it says that it will " not recognise the cd" or "cd improperly inserted"
    if I put an audio cd in the drive then it works fine, only seems to play up with the sat nav CD.
    I have tried it with both satnav CD's and the same thing happens every time.
    I don't know what causes the issue so any help would be appreciated.
    OllyT
    27,108
    Welcome to the site.
    You say CD's, do you mean dvd, do you have the rns-e head unit fitted?
    Oct 2013
    Yeah in pretty sure its the rnse unit. From what i can tell from the pictures in the site.
    It will play audio cd's but will not recognise the sat nav dvd's
    27,108
    Usually I clean the laser head & see if that fixes, otherwise its a new laser/drive, but tbh if it is the drive/laser, with the cost of me repairing, clients have opted just to upgrade to the newer version on a part ex of existing faulty unit.
  1. A4 B7 S-line 2007 sat nav issue.
    By OllyT in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd October 2013, 21:58
  2. sat nav wiring issue
    By francium in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st March 2013, 20:28
  3. RNSE - Sat Nav Issue
    By g00se in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th November 2012, 16:41
  4. issue with sat nav location
    By Mike_R in forum Satellite Navigation
    Last Post: 16th March 2011, 01:27
  5. Aftermarket Sat Nav Headunit issues
    By MixedUp in forum Satellite Navigation
    Last Post: 6th October 2009, 18:32
