AH FabricationsChris Nott
    Nov 2012
    London
    14
    Audi A3 2003 8l Concert to RNS-D Wiring Problems
    I'm having some issues retrofitting an RNS-D to an A3 8l with a non Bose Concert CD
    I've searched previous posts and quite find the answers I'm looking for. I know about connecting +12v to the SAFE pin but I'm confused about what other connections need to be added / re-routed.
    On the attached picture I've circled all the connections the original Concert had. Green shows the connection matches with the RNS-D. Red shows a connection is present but does not match the RNS-D.
    I don't have DIS so I don't need to wire a TMC module. (I think)
    I've got the following questions:
    1) Do I need to connect the CAN-L and CAN-H from the Concert to pins 13 and 26 on connector #4 on the RNS-D
    2) What does "DWA-GND" do on the Concert? And does it need to be re-routed?
    3) Do I need a feed to GALA on the RNS-D? The Concert has GALA (volume adjusts with speed) but I can't see how the Concert knows what speed it's going.
    4) What other connections are required for the 26 pin on the RNS-D
    Thanks for reading this far!
    Nov 2012
    London
    14
    Bump, any takers?
    Feb 2014
    29
    Did you manage to fit your Navigation plus?!
    Using Tapatalk
    Nov 2012
    London
    14
    Quote Originally Posted by Becksbar7 View Post
    Yes in the end.
    Are you having problems with it?
    Feb 2014
    29
    I am indeed!! I currently have a Concert 2 and have purchased a Navigation Plus, but really could do with some help if poasible. Thanks, Rebecca
    Using Tapatalk
  1. Audi A3 S3 8L Concert II to Double Din RNS-D Rare Satnav Installed in a 2002 Audi S3
    By AviatorRichards3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th April 2014, 12:04
  2. Replies: 8
    Last Post: 21st November 2012, 00:30
  3. Audi Concert, Symphony, RNS-E etc?
    By Ben H in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2010, 11:51
  4. Audi b6 2003 concert to symphony 2 upgrade
    By steveboyo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th November 2010, 17:59
  5. audi bus input on concert CD
    By Rollinz in forum In-Car Entertainment
    Last Post: 30th August 2006, 14:48
