Sky InsuranceChris Nott
Results 1 to 7 of 7
    Jun 2009
    39
    MK2 RNSE CD & AMI?
    From much searching/reading it is suggested it is possible to have CD or AMI with the MK2 but not both together due to pin duplication? - I currently have a CD changer, when I go into media it shows the 6 CD's + initialising AMI which would suggest it is possible to have both?
    I guess I could try but not had the time - will any other format (other than MP3) play from the SD cards? ALAC, FLAC etc?
    many thanks
    -Steve
    -Steve
    2004 Audi S4 Cabriolet (current)
    2001 VW Passat 130TDI sport (current)
    2000 BMW E39 M5
    1995 Toyota Supra TT UK spec
    1990 Vauxhall GSi 2000 - massive mods
    27,014
    No, what the issue is, the ami goes in the socket where the changer would, cd & ami do not use the same wires.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    I've done it to two RS6 cars with RNS-E MK2, used the 6 CD changer in the boot and fitted an AMI into the glovebox.
    Jun 2009
    39
    Quote Originally Posted by s8craig View Post
    Apols for the delay... very many thanks...
    Will an 8T0-305-785A CAN AMI work with an RNSE-MK2? read a long US thread on AMI, the 8TO is mentioned though lost track in all the posts what worked and what didnt...
    I am guessing it is the same as the 8P0 just from another model?
    All the best
    -Steve
    -Steve
    2000 BMW E39 M5
    27,014
    The 8T0 ami will not work with an rns-e.
    Jun 2009
    39
    Perfect, thank you.
    Such similar part nos...
    -Steve
    2000 BMW E39 M5
    27,014
    Yeah identical looking aswell
  1. RNSE Bluetooth and AMI Upgrade
    By aky20 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2013, 14:49
  2. SDS high retrofitted to mk2 RNSE (non factory SDS model)
    By wez3570 in forum Satellite Navigation
    Last Post: 31st March 2012, 15:00
  3. rnse making a thump sound via amp?
    By bluequattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2009, 22:04
